K
Korj
Guest
Fix #4: Use WPA2/AES and Enable WMM
Most 802.11n products will knock your throughput down by up to 80% if you use WEP or WPA/TKIP security. The reason is that the 802.11n spec states that the high throughput rates (link rates above 54 Mbps) can't be enabled if either of those outdated security methods are used.
The bottom line is that you can only use WPA2/AES wireless security (or no security at all) if you don't want to throw away lots of speed.
Question based on the above (Wireless Basics): Are there any issues using all G devices and the WPA2/AES setting? Are there situations where you should not be automatically setting your router to the WPA2/AES setting? Any drawbacks to selecting a mixed encryption TKIP/AES?
