a couple of questions
Stardust
Hey all.
In January my AC68U stopped working and I made a quick buy of a RT-AX56U.
It is working, but...
What should I buy now, if it will be supported by Merlin long term?
And has good VPN, etc.?
RT-AX86U, RT-AC86U, or ???
Do to I have new address now, I also got a new ISP.
Internet is now a COAX with a router from ISP.
My router is connected to that router.
Is there a way to avoid the ISP router?
Adapters? Cables? or????
Regards
John Poulsen
That sounds right to me.
Make: Sagemcom, France
Model: F@ST 3890V3 WU
MODEM: 3093BCB30DD
I have deactivated the WiFi part of this and use my router instead.
Regards
John
You will still need to use the ISP device because of its cable modem part. Sometimes you have an option to put the modem into "bridge mode" so that you don't have double NAT (one router behind another router).
There is a "bridge mode", thanks again :)
Now I need a good suggestion about what to buy?
My AX56U are slow when running VPN..
Regards
John
Asus AX routers with hardware AES support CPU's and current Asuswrt-Merlin support are:
RT-AX68U, RT-AX86U, RT-AX88U and GT-AX11000
In my test with similar CPU router I could get up to 170Mbps in 386 firmware, NordVPN servers.
Sounds very to me, I use NordVPN as well, so Tech9, thank you very much :)
Now to the choosing ;)
Why do you want to run VPN Client on your router?
Instead of have to log in with one Mini-PC, 2 Laptops and a Android phone (for now), it is much more simple to run VPN on the router.
I also have a NAS (cable) and Internet radio...
When you need to enable/disable the VPN or change the server you connect to - what you are going to do? It's 2 klicks in VPN client app.
Well nothing, the NAS is like my PC's, etc. on the internal side of the router/VPN.
I'm asking about the convenience. On-device VPN Client requires 2 klicks and 2 seconds. On-router VPN Client requires logging into GUI and starting/stopping/re-configuring the client. What is much more simple on the router?
On Windows and Android yes, on Linux (my favorite OS) no.
It is command line in Linux with NordVPN
