Here's the situation:
I have a basement apartment and the landlords allow me to use their wifi signal for internet. I can not drill holes to run cabling to my PC, so I use this device:
https://www.amazon.com/dp/B007PTCFFW/?tag=snbforums-20
...to pick up the wireless signal, which is wired to a Cisco router's 'internet' port, that I use down here for all my devices. The Cisco router sees the TP-Link as a wired internet connection, as if plugged directly into a modem. My PC is wired to the Cisco router, anything that can't be wired, like my phone or tablet, uses wifi from the Cisco router. I am able to get, so far, an average of 5MBps speeds on my PC through this frankenstein setup.
I was thinking about getting another of those TP-Link devices, and wiring them into a 'splitter', like this:
https://www.amazon.com/dp/B016NUDZ4I/?tag=snbforums-20
...so that 2 plug into the splitter, and one cable connects to the Cisco router. For argument sake I'll assume the splitter is capable of accepting and delivering LAN speeds, I hope anyway.
The questions:
1. Would this result in the speed being compounded, delivering 10MBps speeds?
2. Would it even be possible for the Cisco router to accept an 'internet' connection from, physically the same, but 2 different sources? As in, any IP address confusion.
3. Would the splitter act somewhat as a filter, making the 2 connections look like one to the Cisco router? I'm assuming so, since the router already sees one TP-Link as a wired connection, but I'm not 100% sure...
The questions:
