Eric Mitchell
Aloha all! I have an AC-3200 on the latest Merlin that I've been using for a couple of years. It's been between three houses, three modems, always worked fine.
This morning I upgraded from 300Mbps to 1Gps at the house, and switched again to a new modem (needed DOCSIS 3.1 for the 1G connection). Upon plugging the new modem into my router, it continues to give me the "your ISP's DHCP does not function correctly" error and I have no internet access.
So far, I have tried
The only thing I haven't done is flash an Asus firmware back on the router instead of the Merlin firmware....but don't know why that would work.
About to just go and buy a new router, but hate to as the 3200 was always perfect....until now. This is frustrating! Anyone have any other ideas?
Mahalo from Maui
- Plugging modem straight into Laptop, works fine
- Changed DHCP settings from agressive mode to normal, same
- Factory Reset whole router, same issue
- Go through internet setup on new reset router, didn't help.
- Turned all devices off for 30 minutes, turned modem back on, once booted booted up factory reset 3200, same error.
- Grabbed a brand new RT-AC68U out of the box, plugged it up, boom works fine.
- Compared WAN settings between the 68 and the 3200, they're the same.
Mahalo from Maui
