AC-5300 only 5Ghz-1 band working
@Kashif Tasneem, reading over your posts again, I see that you're jumping back and forth from wildly different firmware.
After flashing the firmware you want to test, do you do a full M&M Config as outlined in my signature below?
If you didn't, there could be the source of many, if not most of your issue(s) right there. :)
Yes, I did follow your steps. I ll do these steps once again :)
forget it, your first picture shows clearly Control channel 0 while set to Auto, which indicates broken Wifi-chips.
After power off and cool down they may come back for some time, return or RMA!
