admin@RT-AC88U-C860:/tmp/home/root#
admin@RT-AC88U-C860:/tmp/home/root# iwlist
-sh: iwlist: not found
admin@RT-AC88U-C860:/tmp/home/root# iwconfig
-sh: iwconfig: not found
admin@RT-AC88U-C860:/tmp/home/root# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:01:5c:78:e0:46
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 60:a4:4c:63:ca:ab
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: b4:ae:2b:19:f6:7a
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 38:d5:47:bd:c8:60
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 4 5 7 8t
2: vlan2: 0 8u
lsusb
admin@RT-AC88U-C860:/tmp/home/root# ifconfig
br0 Link encap:Ethernet HWaddr 38
5:47:BD:C8:60
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:190691 errors:0 dropped:0 overruns:0 frame:0
TX packets:3620764 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:91620852 (87.3 MiB) TX bytes:5143009560 (4.7 GiB)
eth0 Link encap:Ethernet HWaddr B4:AE:2B:19:F6:7A
inet addr:68.83.21.167 Bcast:68.83.21.255 Mask:255.255.254.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4304789 errors:0 dropped:0 overruns:0 frame:0
TX packets:3265414 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:940096813 (896.5 MiB) TX bytes:3454133632 (3.2 GiB)
Interrupt:181 Base address:0x6000
eth1 Link encap:Ethernet HWaddr 38
5:47:BD:C8:60
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:36 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:4724 (4.6 KiB)
eth2 Link encap:Ethernet HWaddr 38
5:47:BD:C8:64
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:608 (608.0 B)
fwd0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
UP BROADCAST RUNNING PROMISC ALLMULTI MULTICAST MTU:1500 Metric:1
TX packets:670 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:93266 (91.0 KiB)
Interrupt:179 Base address:0x4000
fwd1 Link encap:Ethernet HWaddr 00:00:00:00:00:00
RX packets:41453 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12865091 (12.2 MiB) TX bytes:0 (0.0 B)
Interrupt:180 Base address:0x5000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:199372 errors:0 dropped:0 overruns:0 frame:0
TX packets:199372 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:68422771 (65.2 MiB) TX bytes:68422771 (65.2 MiB)
vlan1 Link encap:Ethernet HWaddr 38
5:47:BD:C8:60
RX packets:766949 errors:0 dropped:0 overruns:0 frame:0
TX packets:2311145 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:147572407 (140.7 MiB) TX bytes:3265881907 (3.0 GiB)
vlan2 Link encap:Ethernet HWaddr 38
5:47:BD:C8:60
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wl0.1 Link encap:Ethernet HWaddr 38
5:47:BD:C8:61
RX packets:137 errors:0 dropped:0 overruns:0 frame:0
TX packets:4089 errors:0 dropped:107 overruns:0 carrier:0
RX bytes:7830 (7.6 KiB) TX bytes:608812 (594.5 KiB)
wl1.1 Link encap:Ethernet HWaddr 38
5:47:BD:C8:65
RX packets:353 errors:0 dropped:0 overruns:0 frame:0
TX packets:4506 errors:0 dropped:50 overruns:0 carrier:0
RX bytes:20269 (19.7 KiB) TX bytes:852368 (832.3 KiB)
