jbhap
I recently bought an AC-RT68U router as an upgrade to my home wireless network which I use to connect to my broadband. Frankly, I hadn't noticed the distinction between the AC-RT68U (which doesn't have a built in modem) and the DSL-RT68U (which does), and didn't realise that I would need a separate modem to connect the AC-RT68U.
I'd like to understand more about my options here. As I see it I could either:
1. Use the old router supplied by my ISP (a Thomson TG585 v7) as a modem
2. Buy a new standalone modem
3. Return the AC-RT68U and swap it for a DSL-RT68U for about £10 more
Are any of these options likely to result in substantially better or worse speeds? Will the Asus router work best with its own built in modem? Would a new standalone modem perform noticeably better than using that old router as a bridge? Would I be likely to experience a big difference between a cheap (£10-15) new modem and a more expensive one?
Many thanks in advance for any advice.
