Solved ac3100 giga bit speed not advertised post reboot
mvadu
Setup: ac3100 connected to a raspberrypi 4 using a cat 7 cable.
Issue: Post rebooting the router it does not advertise gbps speed ( 1000baseT/Half 1000baseT/Full ) and only when I unplug the cable and put it back it goes to 1gbps. It stays until router is rebooted.
Post router restart
client side:
ethtool eth0
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
        Current message level: 0x00000007 (7)
                               drv probe link
        Link detected: yes
ac3100:
 robocfg showports
Switch: enabled
Port 0:   DOWN enabled stp: none vlan: 1 jumbo: on mac:
Port 1:  100FD enabled stp: none vlan: 1 jumbo: on mac:
Port 2:  100FD enabled stp: none vlan: 1 jumbo: on mac:
Port 3:  100FD enabled stp: none vlan: 1 jumbo: on mac:
Port 4: 1000FD enabled stp: none vlan: 2 jumbo: on mac:
Port 5: 1000FD enabled stp: none vlan: 1 jumbo: on mac:
Port 7: 1000FD enabled stp: none vlan: 1 jumbo: on mac:
Port 8: 1000FD enabled stp: none vlan: 2 jumbo: on mac:
After unplugging cable and plugging back
 ethtool eth0
Settings for eth0:
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
                               drv probe link
        Link detected: yes
ac3100:
 robocfg showports
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: on mac:
See the change in port 3 speed and Link partner advertised link modes.
Do you not already have a Cat 5e cable you can try? It's just for testing purposes.
P.S. Try not to use flat cables.
Thank you for the pointers. I did replace the cable and after 2 reboots it came back with 1gbps. I am still using a flat cable, but a different one. I should have thought of switching the cable before posting here.
