So it seems that i am not the only one and i saw in a previous post that @jerry6 was also asking if the 2.4ghz radio was fixed.
I am not sure what issues others have, but for me its been worse and worse.
I reboot the router and all clients connect and are happy.
Then during the day (could be close after reboot or later) the router either crashes or reboots (kids saying Dad the internet is gone).
After a little while the router reboots but refuses to let certain clients to reconnect to the 2.4ghz band until i force reboot.
The funny part is that only the clients that only support 2.4ghz like nest protect, my printer, my alarm system, and the ecobee thermostat cant connect. However the client that can connect to a 5ghz band and who try to connect to the 2.4ghz are able to connect.
I automatically reboot my router on a daily basis at 6am.
I am attaching the syslog sections from a regular reboot and a crash reboot. There are some differences (i tried to sync the logs so i left some blanks). Hopefully that can help.
I am currently on 384.3 but was recently on 384.5 and all versions from the one i have and up have the issue (i tried them all). I dont really want to try any more versions.
I also tried to back up the config using nvram save r26.2, re-install the firmware fresh after a factory reset but still.
As anyone found a fix or work around?
Its annoying because my ecobee or ring doorbell loose connection so when i am at work i do not receive notifications any more until i get back home and hard reboot the router.
Any help is welcome.
--Adrien
--Adrien
