AC66R Horrid performance
Find the Door
I'm not able to stream anything in HD without buffering. I've also experienced some minor connectivity issues on my new PS4 as of late too (party drops, could be PS4 isolated).
Here's my results all with the same device taken in the same exact room that the router is located.
Router 2.4ghz band
Router Hardwired
Motorola SB6141 Hardwired directly
Error log:
ec 4 21:07:16 rc_service: httpd 300:notify_rc restart_wireless
Dec 4 21:07:19 kernel: device eth1 left promiscuous mode
Dec 4 21:07:19 kernel: br0: port 2(eth1) entering disabled state
Dec 4 21:07:19 radvd[449]: attempting to reread config file
Dec 4 21:07:19 radvd[449]: resuming normal operation
Dec 4 21:07:19 kernel: device eth2 left promiscuous mode
Dec 4 21:07:19 kernel: br0: port 3(eth2) entering disabled state
Dec 4 21:07:22 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.102.9 (r366174)
Dec 4 21:07:22 radvd[449]: attempting to reread config file
Dec 4 21:07:22 radvd[449]: resuming normal operation
Dec 4 21:07:22 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.102.9 (r366174)
Dec 4 21:07:22 kernel: device eth1 entered promiscuous mode
Dec 4 21:07:22 kernel: br0: port 2(eth1) entering listening state
Dec 4 21:07:22 kernel: br0: port 2(eth1) entering learning state
Dec 4 21:07:22 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Dec 4 21:07:22 kernel: br0: topology change detected, propagating
Dec 4 21:07:22 kernel: br0: port 2(eth1) entering forwarding state
Dec 4 21:07:24 kernel: device eth2 entered promiscuous mode
Dec 4 21:07:24 radvd[449]: attempting to reread config file
Dec 4 21:07:24 radvd[449]: resuming normal operation
Dec 4 21:07:24 kernel: br0: port 3(eth2) entering listening state
Dec 4 21:07:24 kernel: br0: port 3(eth2) entering learning state
Dec 4 21:07:24 kernel: br0: topology change detected, propagating
Dec 4 21:07:24 kernel: br0: port 3(eth2) entering forwarding state
Dec 4 21:07:29 dnsmasq-dhcp[388]: DHCPREQUEST(br0) 192.168.1.35 20:10:7a:4a:b9:f1
Dec 4 21:07:29 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.35 20:10:7a:4a:b9:f1 Mason-HP
Dec 4 21:07:29 dnsmasq-dhcp[388]: DHCPREQUEST(br0) 192.168.1.101 34:23:ba:3f:c2:a7
Dec 4 21:07:29 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.101 34:23:ba:3f:c2:a7 android-45cff283b44aea2e
Dec 4 21:07:30 dnsmasq-dhcp[388]: DHCPREQUEST(br0) 192.168.1.111 c0:d9:62:3c:3c:78
Dec 4 21:07:30 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.111 c0:d9:62:3c:3c:78 COM-MID1
Dec 4 21:17:10 dnsmasq-dhcp[388]: DHCPINFORM(br0) 192.168.1.35 20:10:7a:4a:b9:f1
Dec 4 21:17:10 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.35 20:10:7a:4a:b9:f1 Mason-HP
Dec 4 21:23:09 dnsmasq-dhcp[388]: DHCPINFORM(br0) 192.168.1.35 20:10:7a:4a:b9:f1
Dec 4 21:23:09 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.35 20:10:7a:4a:b9:f1 Mason-HP
Dec 4 21:57:16 dnsmasq-dhcp[388]: DHCPINFORM(br0) 192.168.1.35 20:10:7a:4a:b9:f1
Dec 4 21:57:16 dnsmasq-dhcp[388]: DHCPACK(br0) 192.168.1.35 20:10:7a:4a:b9:f1 Mason-HP
The "Mason HP" is the laptop I was using the test
I just recently updated to Merlin's latest file RT-AC66U_3.0.0.4_374.35_4
Have had issues since, and even before that sometimes while running the latest official Asus firmware
Any insight?
Ended up doing a factory reset. I noticed the power light would blink intermittently before doing it (three blinks then off).
I reset everything, and everything is functioning now. Not sure what happened?
