ac66r No login webpage
Xyrem
Hello,
I have a weird problem that I cant figure out. I went to login to the router yesterday, to see why my Sprint Airave (cellular VOIP) was not connected to the Sprint. I figured out that my cable was down, hence the issue.
My weird problem is that when I go to the IP of the router, I get this message.
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-AC66R.
To access the settings of RT-AC66R, reconnect to the wireless network and use the updated IP address and port number.
The router does not reset and I cant login to the router. I have power cycled the router, attempted a firmware restoration in recovery mode (fails due to functional router) and I'm still no closer to getting into the router.
I'm sure there is something simple and I am missing it. Any ideas?
Try another browser. It worked for me. I cant tweak certain settings in my router from Chrome, only Safari. Weird, I know. But thats my experience.
You can also try to clear the cache in the browser, and then try to connect again.
Hmmm. Another browser does not do the trick for me anymore. I get the same message as Xyrem.
Can not access my routers UI from any of my computers. Do I have to use a cable to do it? I am only connected via WIFI now.
I had the same thing happen to me yesterday. I kept power cycling it but that didn't work. I had to press the reset button on the back of the router to get it to come back.
