adampk17
RT-AC66U with 380.68 Merlin release.
Months ago the 5 GHz radio stopped working if the channel bandwidth option chosen was either of the options that have 80 MHz in them. 20 MHz and 40 MHz worked fine, 80 MHz and 20/40/80 did not. The SSID could never be found.
Last week the router started restarting itself every couple minutes. After much troubleshooting, including factory resets, opening the router, cleaning the dust out, and firmware recovery, I've determined that if the 5 GHz radio is turned off the router behaves normally again.
Anyone seen this with this model before?
Thanks in advance
Thanks in advance
