AC66U - Any way to avoid the certificate error while using AIcloud 2.0?
m33ts4k0z
Hello,
Recently, I purchased this router and I'm very impressed with it. I have one small problem through.
Everytime I try to access my shares through the web interface, all browsers will give red warnings about the certificate not being trusted and such.
I wonder if there is a way to fix this. I noticed online that there is a way to upload certificates to the router through telnet, will that fix the issue?
Thanks in advance.
You would need to own a domain name, and purchase a certificate from a known certificate authority.
Hello and thanks for your reply. I own a domain and I'm using a starcom startSSL certificate. I've managed to get my router page to appear as trusted but I dont seem to succeed with the AICloud web page although it is on the same subdomain as my routers.
Any suggestions?
Hello and thanks for your reply. I own a domain and I'm using a starcom freeSSL certificate. I've managed to get my router page to appear as trusted but I dont seem to succeed with the AICloud web page although it is on the same subdomain as my routers.
Any suggestions?
When you log on AiCloud, there's an option there to upload a certificate. I've never tried it myself, but I would assume that it should work.
Wow how the ... did I miss that? Thanks it indeed worked great. Thanks for the great firmware as well. Cheers
