Hi Guys,
OK this is crazy but I'm posting b/c it might make sense to someone. It sure baffled me.
Answers with background history.
Both of these routers are used as WAPs. I have 2 WAPs for redundancy which also allows me to upgrade one unit without hearing howls from the family about why the wireless is down. I just tell them to switch to the other unit while I upgrade.
To answer martinr's question: I do not remember 100% but it was very likely during my long overdue upgrade from 380.64_0 the 380.66_0 versions. Now, as a best practice and per this comment we are posting, I mark my calendar and upgrade every 1-2 months to keep the version jumps small.
To answer the question about using http/s://192.168.1.1. No, I'm sorry I did not but since I could ping both router's address (192.168.xxx.15 and 17), I'm 100% sure they were online. Also, since I had wireless connections to either, I concluded both WAP were actually booted and working, just no WEB GUI to administer them.
TY, the link is great! I generally follow the posting's outlines but this time, I got sloppy, see below:
1) Make backup cfg from Web GUI
2) I have no customized JFS partitions
3) Remove the USB (sorry I did forget this time on the AC1900 but there's nothing on the USB now that I stopped using the backup utility you mentioned and I stopped writing cstats to the drive. The AC88U had no USB to begin with.
4) I did NOT reboot either router BEFORE upgrading. My BAD b/c I agree, doing that seems to make things go smoother. I was distracted and just forgot.
5) Yes, I did a hard / cold reset afterwards, more than once by turning off the power to the routers and pulling the plugs.
On the NVRAM backup utilities. I used these for a couple of years but the last time I tried to restore, they did not work too well and I lost all my settings on all 3 routers. I'm sure it was b/c the jumps were too large. So now, I just backup the settings before I upgrade the FW and hope for the best.
Now, strangely enough, here's what I did to "fix" both and it gets weird:
1) After messing around on the RT-AC1900 last night and this AM, I connected to PORT1 wired, booted to recovery mode and then used ASUS restore utility to flash Merlin's 380.66_4 into the router. Power rebooted afterwards and WEB GUI popped right up snapo, no issues. I also tested connecting wireless, no issues. All of my settings were in place without restoring them from the WEB GUI backup.
2) On the RT-AC88U, I connected to PORT1 wired and just for hell of it, I refreshed / connected via the WEB GUI (
https://192.168.xxx.17:8443) again and WOW, the WEB GUI popped right up in FF, no spinning, no delays. Hmmmm, OK I thought. I did not restore it or do anything else to it.
As a general rule, I keep PORT1 open so I can always connect there. I typically use a higher port for the WIRED connection from the WAP to the main switching gear. I know it should not matter.
In this case, since connecting to PORT1 in both cases seems to have allowed the WEB GUI to work, I am suspicious now. When I flashed both of these, the connection was wired but through a HIGHER port#. So could being connected on something other than PORT1 be causing issues with WEB GUI connection after this upgrade? I D K.
Now it gets weirder...
So then I went back and said OK, I can put the AC1900 back if needed so I put my up-link cable into port 1 on the RT-AC1900P and then I re-flashed it using a wired connection from 380.66_4 to 380.66_6.. hard rebooted it and the WEB GUI popped right up this time.
So, bottom line is... Could
not being plugged into Port 1 for connecting the routers during this upgrade somehow causing the WEB GUI troubles like this? I know this sounds really, really strange but that's the way it is played today.
I do not use any extra features, no CIFS, no JFS, nothing but wireless basically as a WAP.
I have a 3rd RT-AC1900P which acts as one of the main internet facing routers, so I'm going to make sure the connection from the main switches is into port 1 before I attempt to flash it b/c messing that one up will bring down the whole house's internet service and the howls will begin.
Thoughts?
G. Mobley
