[AC68U] Problems with NameCheap DDNS
I was using this setup and the custom script to get this working with NameCheap DDNS, but I've recently switched to using DNS-O-Matic and I cannot get the Let's Encrypt certificate issued now.
I've created a ddns-start script for DNS-O-Matic and that seems be working just fine and I can get it to update the IP address. I then changed the option to Custom and put in the FQDN and I'm still stuck on:
Unknown or processing...
the FQDN was entered as:
subdomain.mydomain.com
I first tried using DNS-O-Matic from the dropdown menu and that worked for updating, but in the system log I would see the Let's Encrypt Error:
Oct  5 12:30:05 kernel: Create new order error. Le_OrderFinalize not found. {
Oct  5 12:30:05 kernel:   "type": "urn:ietf:params:acme:error:rejectedIdentifier",
Oct  5 12:30:05 kernel:   "detail": "Invalid identifiers requested :: Cannot issue for \"subdomain\": Domain name needs at least one dot",
Oct  5 12:30:05 kernel:   "status": 400
Oct  5 12:30:05 kernel: }
Now when using Custom and the FQDN, I don't see anything in the logs about system even doing anything with Let's Encrypt...just see a note about ddns-start running
