AC86U (Merlin 384.14_2) WebGUI hung
What are the WAN and LAN IP's for this router?
@JGodfrey82 what router and firmware are you running? I hope not the firmware of this thread?
Like I said, everything works except webgui being bound to openvpn interface.
Your Web GUI is at 192.168.48.1, it doesn't automatically bond to anything else.
Correct, my question was how to bind it to openvpn interface. I'm not a beginner, I'm certain it's passing traffic I just need the service to bind. I know there isn't a config and runs from nvram so was just hoping someone may have run into this and knew a command line I could add the binding. I've tried manually starting httpd but haven't gotten the switches figured out.
What's the goal? You want to access it from where?
You want to get to router's GUI when the router's VPN client is active, correct?
From WAN - you have to route router's own IP address through WAN first
From LAN - you should be able to get the GUI by IP address, if router.asus.com doesn't work
