Hello everyone,
I'm trying to decide between these two models. I had been running the trusty AC68U, but I have been itching for an upgrade and the AC88U and AC86U are at the top of the list.
I have a 1,400 sqft home, so reaching all the corners of my house probably won't be too much of an issue for either. I understand that the 86U has the superior CPU, giving it an edge in the VPN department as well as maybe Adaptive QOS and AiProtection. While I do utilize openVPN, I only connect to the LAN, not both WAN and LAN. I also use Adaptive QOS and AiProtection. I won't be using the USB attached storage option - I currently use a Synology NAS.
Right now I use a switch behind the 68U because I have more than 4 devices hardwired, which gives the AC88U the edge with it's 8 ports.
I might try AiMesh down the road with the AC68U as a node at some point, so I'm guessing the AC86U would be better in this regard with it's beefier CPU.
With all that being said, is one model preferred over the other at this time? Is there maybe some features that I might not know about that gives one an edge over the other? The AC88U is a couple years old, and that worries me a tad, but the same can be said about the 86U being so new - who knows if it has hardware revisions down the road or other quirky things with the hardware/software. Not to mention failure rate for either...
Any guidance is appreciated.
Thanks in advance.
Thanks in advance.
