AC87U Issues and doubts
wsarahan
Hi guys how are you?
I just bought my AC87U and i have one issue e two doubts
When i`m suing the router at Load-Balance the ethernet led stays red but the connections are fine, if i turn off and turn on the leds it comes back to normal, all leds blue, is it a know issue?
And what means Port1 and Port2 be Teaming Ports? I`m using the both wans at this ports, the main wan at port 1 and the second wan at port 4
At my old 68U i was using the ports 1 and 4 and i had to use the command:
nvram set switch_stb_x=0
nvram commit
reboot
Because i use the IPTV 10 value
Should i make this command again at the 87U or it`s not necessary? Should i use the team ports to both lans? Please let me know
