DS1819+ and 10Gb Ethernet and M.2 Adapter Card E10M20-T1
I uncoupled the 4GB ports and only the 10GB port is connected now:
the cat/sys etc. gets the confirmation of 2500 as the speed.
So the driver is linking a 2.5Gb, but the net profile is 1Gb
Is this a synology install, or did you load this in docker?
Because you have to add --cap-add=NET_ADMIN to the docker's run statement to alter this.
Docker is a virtualization program. Which some think it provides a layer of safety, but is quite hackable if it was exposed to the internet.
looking at this, we would have to alter the .jason file in /usr/syno/etc/packages/Docker/
Thank you for your inputs and your patience. I will dig into this a bit more when I have some more time.
That's cool, feel free to bug me if you have any questions.
On a side note, I have an old synology NAS I was going to get running again, but I think I will try getting a copy of Ubuntu IOT Os to run on it instead of Synology's "choices" if there really is any.
To break down the Intel's default ip profile setting of 10Gb:
9000 MTU - maximum transmission units at highest link
txqueuelen 2500 - queue length of network (2500 pps based on a 4 port 2.5Gb + 2 port 10Gb switch)
