David Tanaka
I have a AC88U I just purchased. I have about 45 or 50 various devices hooked to it and I assigned IP addresses to most all of them. After adding about 45 then the router seemed to slow down and then lock up. But sometimes it would not let me have the web interface, but it would still route to the internet. I have had to reset and reload the firmware about 8 times. I would save configurations at times when everything was working. The preverbal straw that would break the camel’s back was adding the assigned IP address in DHCP after about 45 or so. Finally, after the 8 or maybe 10th time, I just loaded a configuration that worked and left it. It has been working for 24 hours.
When I first got it, I was like a kid in a candy shop and turned on all the AI protection stuff. So, all the AI protection was the first thing I turned off when it froze the first time.
Then I read OpenVPN can create old certificates that fill up NVRAM so I turned that off same thing. Furthermore, I have been monitoring my NVRAM and it never goes beyond 65000.
I can’t find anything in the logs that jump out.
I found many issues close but not exactly the same. I can’t imagine assigning IPs to devices could cause it to lock up. Furthermore, this is a higher end router so I would expect it would not lock up so easily. So, I am reaching out to figure out if anyone knows what is going on.
This what I am using.
Merlin Version: 380.68_4
OpenVPN
DDNS -Dnsomatic
There are three port forwards.
Wifi and Guest Wifi
Using OpenDNS for DNS
THanks
David
OpenVPN
DDNS -Dnsomatic
Wifi and Guest Wifi
THanks
David
