My setup was main router AC88U connected to optical modem with RJ45 WAN port.
The output of AC88U will go to various RJ45 of my various rooms.
This act as my main router with wifi disabled.
Floor level1 has RJ45 connect to AX88U as the main WIFI mesh.
Floor level2 is the AX11000 as the node.
The Wifi scheduler is enabled to always off at night and on in the morning. This is control via the main Wifi mesh AX88U.
With the previous main release (388.6_2 for the AX88U and AX11000 with AC88U being 386.12_6), I dont see any problem with the AIMESH with what I configured above.
With the latest main release AX88U/AX11000 for 388.7 and AC88U being 38613, I encounter consistent problem with the AIMESH.
I dont think it is AC88U issue since this act as the main router.
The issue is after the AIMESH established and able to work for few days (4-5 days) I will find the SSID_5G will not be able to detect by my wireless client. I have to do a reboot for the main+node before I can see the SSID_5G
The AIMESH main and node are connected via SSID_5G-2 and was set as the priority for the two to communicate.
It is weird that this happen only after the latest release. Is this reported by anyone or is this a known issue?
Best Regards,
Wee-How
Best Regards,
Wee-How
