Hello,
I'm having an issue with my router for quite some time now and I can't find a solution. I've changed every piece of hardware on my network including the router itself but it didn't make any difference.
It's that the router stops resolving DNS address on all clients on the network once very some days for some minutes(usually 1-2 minutes) and then resumes normally.
Under this time all clients (wired and wireless) report "connected but not internet access". During this problem, I can browse the LAN normally but I haven't tried to ping on an IP address outside my network yet.
I have many devices (around 15) connected through wireless and wired so I wonder if the temperature can be a factor that affects or causes this behaviour. I don't know the temperature of the router when this is happening but if it can be the issue I will check and reply here.
Thanks in advance
Thanks in advance
