Oferlaor
Hi all,
Had a similar issue to the one described in the "WAN disconnect" thread, but also different enough so that I am opening a separate thread.
I have an AC88u (i.e., non HND) running Merlin 386.5_2, it's connected via a 1Gbps WAN connection to a fiber connection, using PPPoE for connectivity. I have VPN on, but only for specific clients (using openVPN to "unlimited VPN service"). I use Connect to DNS Server automatically "NO" with 1.1.1.1 and my primary and 8.8.8.8 as my secondary.
It has been running stable, but last night there was a very weird disconnect. Most of my network was down (no ping to 8.8.8.8 so not just DNS), but some clients still managed to get out to the internet. I was able to get out, but the WAN display showed "disconnected".
I rebooted both the fiber adapter (physically) and the AC88u (by pressing reboot on the GUI). It made things worse, after reboot nothing worked. Fiber adapter showed a steady connection. Multiple disconnects and reconnects between fiber adapter and WAN connection did nothing. Ultimately, a hard (physical) restart of the unit revived the internet connection.
Nothing interesting was in the logs (including no info on failed PPPoE connections). That's the weird part, I would expect the logs to reflect it trying and failing to do ... Something...
should I switch to my ISP's DNS clients? Any ideas?
