darkphader
Need wireless coverage for a small business, both bands and N, to replace several Netgear WNDAP350's as they just haven't been entirely reliable (mostly dropped connections), although I do like their feature set for the most part such as logging to a syslog server, they do not support IPv6 and are reasonably expensive.
I do NOT need any routing features and as any (AFAIK) router can also be used simply as an access point, might I be better off with something like several RT N66U's? I would gain IPv6 support (although not needed today, will be in the future), better performance, the aiblity to use DD-WRT (if the performance as good with this?) etc. Or should I switch to something like multiple WAP321's (although the whole Cloud Connect debacle leaves a bad taste in my mouth)?
What else should I be considering?
Thank you.
Chris
Thank you.
Chris
