Access points - what should I seek?
EngChi
The house hunting went from theoretical to close date in 3.5 weeks , the house we are buying has no wiring (so it would be added to each bedroom/office) and I would like to add ceiling mounted access points for wifi coverage
I intend to use Mikrotik RB750Gr3 as router between IPS(s) and LAN and looking for the rest of equipment recommendations.
Thank you
Look at Netgear ORBI can be the one and only you need or EdgeRouter with a UniFi AC Pro AP
Thank you - never heard of ORBI and am reading about it now.
My preference is probably more traditional set up - willing to pay for and set up at least gigabit wires to each access point, only use wireless where no other option is possible (phones, tablets) with the rest wired. don't need crazy 'wireless backbone' things or cute smartphone apps. Just want something that works, gets regular updates for things like security vulnerabilities and is somewhat manageable.
looked at mikrotik - wealth of options I do not yet understand and multiple threads on how their devices and keep alive packages kill batteries on attached mobile devices by not allowing them to go to sleep
looked at UniFi - probably default option, wondering how I will structure this and whether I need any other devices in addition to RB750Gr3
In my 'old' and my smaller house, pfsense handled all of the routing/firewall, TP-link Acher C5 was the access point connected over cat5e to the network and dump switches in between
look at the ubiquiti unifi ac series ap's , they work great and the lite version isnt that expensive
