accessing Hulu w/ policy rules
zimv20
setup:
- Asus RT-N66U
- Merlin 380.58
- Roku 2
- ExpressVPN
for months, i was able to successfully use OpenVPN policy rules to redirect Roku traffic through an ExpressVPN endpoint to stream Hulu. recently, it stopped working. i have not made any changes to the setup to cause that, afaict.
using either of these 2 methods, i can confirm successful Hulu streaming through a specific endpoint:
- using the ExpressVPN iOS app
- on the router, routing all traffic instead of using policy rules
... so i believe the ExpressVPN endpoint is good.
i do not want to redirect all traffic through this VPN endpoint, so i am trying to understand the difference between that and using the policy rules.
to configure the OpenVPN client, i downloaded a config file from ExpressVPN. here is the custom configuration:
fast-io
remote-random
pull
tls-client
verify-x509-name Server name-prefix
ns-cert-type server
route-method exe
route-delay 2
tun-mtu 1500
fragment 1300
mssfix 1450
keysize 256
sndbuf 524288
rcvbuf 524288
here is a startup log (here, i am redirecting 2 devices):
Sep  4 03:10:49 rc_service: httpd 6595:notify_rc start_vpnclient2
Sep  4 03:10:50 kernel: tun: Universal TUN/TAP device driver, 1.6
Sep  4 03:10:50 kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Sep  4 03:10:50 openvpn[7368]: OpenVPN 2.3.10 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Mar 20 2016
Sep  4 03:10:50 openvpn[7368]: library versions: OpenSSL 1.0.2g  1 Mar 2016, LZO 2.08
Sep  4 03:10:50 openvpn[7370]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep  4 03:10:50 openvpn[7370]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file
Sep  4 03:10:50 openvpn[7370]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep  4 03:10:50 openvpn[7370]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep  4 03:10:50 openvpn[7370]: Socket Buffers: R=[118784->237568] S=[118784->237568]
Sep  4 03:10:50 openvpn[7370]: UDPv4 link local: [undef]
Sep  4 03:10:50 openvpn[7370]: UDPv4 link remote: [AF_INET]184.173.170.208:1195
Sep  4 03:10:50 openvpn[7370]: TLS: Initial packet from [AF_INET]184.173.170.208:1195, sid=cd5c2993 1cbc32c2
Sep  4 03:10:50 openvpn[7370]: VERIFY OK: depth=1, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=ExpressVPN CA, [email protected]
Sep  4 03:10:50 openvpn[7370]: VERIFY OK: nsCertType=SERVER
Sep  4 03:10:50 openvpn[7370]: VERIFY X509NAME OK: C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server, [email protected]
Sep  4 03:10:50 openvpn[7370]: VERIFY OK: depth=0, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server, [email protected]
Sep  4 03:10:51 openvpn[7370]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep  4 03:10:51 openvpn[7370]: Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep  4 03:10:51 openvpn[7370]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep  4 03:10:51 openvpn[7370]: Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep  4 03:10:51 openvpn[7370]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Sep  4 03:10:51 openvpn[7370]: [Server] Peer Connection Initiated with [AF_INET]184.173.170.208:1195
Sep  4 03:10:53 openvpn[7370]: SENT CONTROL [Server]: 'PUSH_REQUEST' (status=1)
Sep  4 03:10:53 openvpn[7370]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.11.0.1,route 10.11.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.11.0.22 10.11.0.21'
Sep  4 03:10:53 openvpn[7370]: OPTIONS IMPORT: timers and/or timeouts modified
Sep  4 03:10:53 openvpn[7370]: OPTIONS IMPORT: --ifconfig/up options modified
Sep  4 03:10:53 openvpn[7370]: OPTIONS IMPORT: route options modified
Sep  4 03:10:53 openvpn[7370]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sep  4 03:10:53 openvpn[7370]: TUN/TAP device tun12 opened
Sep  4 03:10:53 openvpn[7370]: TUN/TAP TX queue length set to 100
Sep  4 03:10:53 openvpn[7370]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sep  4 03:10:53 openvpn[7370]: /usr/sbin/ip link set dev tun12 up mtu 1500
Sep  4 03:10:53 openvpn[7370]: /usr/sbin/ip addr add dev tun12 local 10.11.0.22 peer 10.11.0.21
Sep  4 03:10:55 openvpn[7370]: /usr/sbin/ip route add 184.173.170.208/32 via 174.116.120.1
Sep  4 03:10:55 openvpn[7370]: /usr/sbin/ip route add 0.0.0.0/1 via 10.11.0.21
Sep  4 03:10:55 openvpn[7370]: /usr/sbin/ip route add 128.0.0.0/1 via 10.11.0.21
Sep  4 03:10:55 openvpn[7370]: /usr/sbin/ip route add 10.11.0.1/32 via 10.11.0.21
Sep  4 03:10:55 openvpn-routing: Configuring policy rules for client 2
Sep  4 03:10:55 openvpn-routing: Creating VPN routing table
Sep  4 03:10:55 openvpn-routing: Removing route for 10.11.0.1 to tun12 from main routing table
Sep  4 03:10:55 openvpn-routing: Removing route for 0.0.0.0/1 to tun12 from main routing table
Sep  4 03:10:55 openvpn-routing: Removing route for 128.0.0.0/1 to tun12 from main routing table
Sep  4 03:10:55 openvpn-routing: Adding route for 192.168.1.112 to 0.0.0.0 through VPN client 2
Sep  4 03:10:55 openvpn-routing: Adding route for 192.168.1.139 to 0.0.0.0 through VPN client 2
Sep  4 03:10:55 openvpn-routing: Completed routing policy configuration for client 2
Sep  4 03:10:55 openvpn[7370]: Initialization Sequence Completed
can anyone help me understand why there is different behavior between redirect all and policy rules, and/or determine how to get Hulu streaming again using policy rules?
