ActionTec 2.5 MoCA Adapter IP Address?
ds5686920
I have two of the current model ActionTec 2.5 Gbps MoCA Adapters I use to extend my WiFi network (4 floors including garage). How do I find the IP Address assigned to an adapter's Ethernet port? It appears like a ghost where my software network tools don't see the adapter. The MAC Address also doesn't show up in the device list. I would like to log into each to set up MoCA security. How do I go about this?
i recall that you have to set the ip address of a pc to the native address of the device and then connect directly with ethernet cable in order to change the address manually. Then you can install back into your network.
AT support should be able to provide if you cannot find it by searching this forum's messages.
