Adaptive QoS and HW acceleration
Morpheus2020
As @RMerlin said, Adaptive QoS of all ASUS WiFi 7 routers is Broken.
In a previous firmware of RT-AX86U, the reason why Adaptive QoS was broken was incompatibility with Broadcom's hardware acceleration. The solution is to manually turn off hardware acceleration in SSH.
fc disable
fc flush
runner disable
nvram set runner_disable="1"
nvram set runner_disable_force="1"
nvram set fc_disable="1"
nvram set fc_disable_force="1"
nvram commit
Turn on hardware acceleration or Restore to default:
nvram set runner_disable="0"
nvram unset runner_disable_force
nvram set fc_disable="0"
nvram unset fc_disable_force
nvram commit
runner enable
fc enable
Users of ASUS BE routers can try turning off hardware acceleration and then test whether Adaptive QoS is available. I'm not sure if the reason why Adaptive QoS of ASUS BE routers is broken is related to hardware acceleration. I'm also not sure if the above method is useful.
If someone is willing to test and tell me the results of whether this method is useful, I would be very grateful.
fc disable
fc flush
runner disable
nvram commit
nvram commit
runner enable
fc enable
What am I looking for? After doing the above and agreeing to the agreement that popped up I got a warning that it would take several minutes for QoS to be active. Everything "appears" to be working
From the log:
Mar 18 16:35:46 ripshod SIG_UPDATE: current sig : 2066
Mar 18 16:35:46 ripshod SIG_UPDATE: latest sig : 2448
Mar 18 16:35:46 ripshod SIG_UPDATE: < sig_ver, Do upgrade
Mar 18 16:35:46 ripshod SIG_UPGRADE: wget trf FULL : Official
Mar 18 16:35:46 ripshod SIG_UPGRADE: wget sig, exit code: 0
Mar 18 16:35:46 ripshod SIG_UPGRADE: wget rsa, exit code: 0
Mar 18 16:35:46 ripshod SIG_UPGRADE: Download trf/rsa OK
Mar 18 16:35:47 ripshod SIG_UPGRADE: sig check OK
Mar 18 16:35:47 ripshod SIG_UPGRADE: mv /jffs/signature/rule.trf to jffs
Mar 18 16:35:47 ripshod SIG_UPGRADE: Do restart_wrs
Mar 18 16:35:47 ripshod rc_service: rc 5519:notify_rc restart_wrs
To me that could be a normal firmware update check.
Okay. Slight decrease in download speed (from 520 to 501Mbps) and no decrease in wireguard speeds. Looks like you have it
These commands would help determine if it’s working or not.
tc qdisc show dev br0
tc -s class show dev br0 parent 1:
tc -s filter show dev br0
grep -oE " mark=[0-9a-f]+" /proc/bw_cte_dump | sort | uniq -c
Any good for you?
Gilly@ripshod:/tmp/home/root# tc qdisc show dev br0
qdisc noqueue 0: root refcnt 2
Gilly@ripshod:/tmp/home/root# tc -s class show dev br0 parent 1:
Gilly@ripshod:/tmp/home/root# tc -s filter show dev br0
Gilly@ripshod:/tmp/home/root# grep -oE " mark=[0-9a-f]+" /proc/bw_
     31  mark=0
    170  mark=10002
      2  mark=1400000
    112  mark=149003d
     18  mark=1490076
      1  mark=2400000
     12  mark=289003d
      1  mark=3c00000
      9  mark=400000
   2077  mark=410002
     26  mark=490076
     34  mark=800000
      2  mark=80000000
    144  mark=80010002
     54  mark=80400000
    239  mark=80410002
      1  mark=804d00de
      4  mark=805400b9
      6  mark=80800000
      5  mark=8080007f
      1  mark=80830005
      2  mark=808d000f
     18  mark=808d00be
      2  mark=808d00de
      2  mark=8092003f
     29  mark=809400b9
      2  mark=809400ba
      1  mark=809400c2
      1  mark=809400c3
      1  mark=80980003
      1  mark=80c40032
      1  mark=80c400c1
      2  mark=80cd00ea
    102  mark=80d2003f
     15  mark=80d400b9
      1  mark=81000000
     43  mark=81400000
      5  mark=814d000f
      2  mark=814d0086
     19  mark=814d00de
      2  mark=8153005e
      1  mark=815400ba
     51  mark=815400bd
      1  mark=81800000
      1  mark=81c00000
      1  mark=82000000
      2  mark=8245005f
      1  mark=824d0017
     35  mark=825400b9
      1  mark=825400ba
      5  mark=829400b9
      3  mark=82c00000
      2  mark=82d400b9
      2  mark=83000000
      1  mark=831400b9
      1  mark=83400000
      1  mark=83c00000
      2  mark=8d00de
      2  mark=9400b9
      2  mark=c00000
That's a shame :(
Let me know if I can do anything else ;)
@Ripshod The output you provided..was that with H/W acceleration enabled or disabled? I don't think it matters just curious if the output would be different if H/W was enabled (or vice versa). Thanks!
That's a shame
On the plus side, it seemed to identify many BitTorrent connections on your network, but had no QoS structures (qdiscs, classes, filters) setup to manage them.
That was with the hardware acceleration disabled, as per your first block. Just for you I've run the commands again but with H/W acceleration enabled along with Adaptive QoS so you can compare (if there is any difference).
     10  mark=0
      1  mark=1000000
     40  mark=10002
      1  mark=1800000
      6  mark=1c00000
     32  mark=1c9003d
      4  mark=1c90076
      1  mark=2000000
      1  mark=2400000
      1  mark=2800000
      2  mark=2c00000
      1  mark=3000000
      2  mark=306000c
      1  mark=3400000
      1  mark=349003d
      1  mark=3c00000
      4  mark=400000
    268  mark=410002
      1  mark=490076
      6  mark=800000
      9  mark=80010002
      6  mark=80400000
     12  mark=80410002
     16  mark=8092003f
      1  mark=809400b9
      1  mark=80d400b9
      5  mark=815400b9
      3  mark=81c00000
      1  mark=81cd000f
      1  mark=81cd0086
      4  mark=81cd00de
      9  mark=81d400bd
      1  mark=831400b9
     21  mark=c00000
      1  mark=cd00de
Another test would be to run these commands in two separate windows:
tc monitor
Leave this running to log any tc commands from tcd process.
service restart_qos
Watch the first window and see what, if anything, it captures. Ctrl-C when it seems to be “done”.
tc monitor
service restart_qos
Absolutely nothing in the monitor session, both H/W acceleration enabled and disabled.
dave14305 is an expert in QoS. His testing method is more accurate. In addition, there are some indirect testing methods.
When you turn on adaptive qos and use some software to fully utilize your download bandwidth, the value displayed by WebUI-Bandwidth Monitor(near adaptive qos) should be close to your actual bandwidth, rather than an abnormally low value. You can also fill in a very low value in WebUI-Adaptive QoS, such as 50M download bandwidth, and then test the speed. If Adaptive QoS is useful, your speed value should be close to 50M.
I'm aware of that. I'm also fully aware that the decrease in download speed I saw was caused by disabling H/W acceleration.
I've helped with development of a couple of add-on scripts, turning my time and my system over to the developers, and @dave14305 has shown to me and others exactly how knowledgeable he is on numerous occasions.
@dave14305 No takers so I bit the bullet and installed AsusWRT 3.0.0.6.102_37103 and ran the tests. Same result :(
Nothing to see here.
@Ripshod BE88U 3.0.0.6.102_37963 is released. Do you want to test it? LOL😄
Adaptive QoS is still non-functionnal for WIfi 7 devices, and I don't expect it to get fixed anytime soon.
Does ASUS know that Adaptive QoS of their WiFi 7 routers is broken? This issue has existed for about a year.
