peevesillinois
Hello!
I'm using a RT-AX58U V2 that is being fed with a 5G-connection through a bridged ZTE-router. Most times I get about 500 Mbit/s download and 20 Mbit/s upload. Bad times I'm in the low 40 Mbit/s. The main question is whether Adaptive QoS is applicable under this circumstances? I read somewhere that the router continuously is supposed to check the current connection speed and adapt QoS accordingly, but I would like to know more about this. How often does is check, every second, minute, hour, day?
Also, regarding the QoS-categories. how to identify what a certain activity is categorized as? Let's take Microsoft Teams and Slack as two examples, which are key during working from home. Would they fall under Video & Audio streaming, Working-from-home or Learning-from-home? It's tricky to set prio correctly. If it even matters at all.
Thanks!
Best / P.
Thanks!
Best / P.
