Solved Add-On Screen
TonyK132
Is there any easy way to fix the Addonn screen without doing reinstall? Somehow (I do not know how) I have 3 tabs, with the 1st being Uptime Monitoring but it is displaying ntpMerlin. Tab 2 is the real ntpMerlin, and tab 3 is the real Uptime Monitoring.
Reboot the router.
I did. No help.
I see you are on older firmware still. Have you at least updated amtm fully and all scripts, including Entware?
