Adding my router before my work computer
katana13
I'm normally good at searching and following guides etc but I don't even know the name of what I'm trying to do here. I would like to setup my Tomato shibby WRT160NV3 in between my work pc and lan port. so that I can setup my wifi network.
I cloned my MAC address of the work pc, set same IP range and the router/wifi works swimmingly. However, I can't access internal work sites from the work pc when I hook up the cable from the router. I thought it was DMZ but it's not working and can't set router to show same default gateway or connection-specific dns suffix as the original connection straight from the wall?
What is this called that I'm trying to do? I obviously don't have any tech support from work as they don't want deal with any issues I have or will have in the future.
Check with your IT folks first - or the next step might be updating the resume/CV :)
You have your home network, and you want to connect to your work network?
Typically, you would have a work provided VPN client on your laptop, for work, that you use to connect to your works IP Space / Services.
you are trying to circumnavigate the companies user policy and code of conduct and possibly getting your self fired as unless you are specifically given permission to do such you are creating a big security issue and potential issues for the whole work network
