Additional Device Icons
And Dell's gaming brand.
Asus PC's and their gaming brand.
Finally, here's the Lenovo machines. Hope you guys enjoy them. I think I'm done for a bit. :)
There's a stock icon for a Linux workstation. I don't have any Linux machines so I haven't made any.
Yes, just didn't know if there was a standalone one, as my Linux device is not a workstation. Thanks!
What kind of Linux device do you have? SoC/embedded? Laptop? I could always make you an icon. ;)
If you have a Sense electric monitoring system here is an icon for it.
Hi !
Here is my contribution, a complete pack of transparent icons :
amazon-echo-dot-2018.png amazon-echo-plus-2018.png amazon-fire-tv-stick-2019-frandroid.png Ampoule.png ATOTOA6.png
PS : There's too much icons to share here, and I can't upload a zip file directly on the forum, so here's a link to my dropbox, please let me know if there's any risk for my dropbox personal content doing so, that's the first time I share from my Dropbox on a public place !
https://www.dropbox.com/sh/qp24poeaon0rmro/AABkRCtd5zPRC6dSPLPnqQxVa?dl=0
here's two more that where missing. To find more for you easily, just go on google images and type "[xxxxxx] transparent imagesize:300x300", clic on the image you want, and look on the right to see if the image appears on sort of a checkerboard instead of the white or black background. If so, it's a transparent one ;) You can play with the "300x300", adjusting sizes to find other pictures, but try to stay on squarred ones to avoid resizing. I had to cut some images on a trasparent background because I couldn't find them with the method described, using GIMP (free). Not too complicated, but it would be hard for me to explain in english, so I'll let you search for tutos ;)
You also can use Paint 3D and any phot0 or use a jpeg file you find, edit it then save it as a *.png file. Just a note the router will display jpeg images as icons with no issue than perhaps using more memory.
Yes, I forgot to tell about *.png^^ And didn't try with Paint3D, just tried with "normal" paint, which didn't work, then used Gimp, as I already knew this program ;)
Do these icons survive a factory reset (and jffs wipe)?
I set up my router from scratch, but somehow still had a Belkin icon that I don't see in the default set.
I think they do get wiped because they are added to /jffs/usericon folder. But there are some that seem to appear that aren't in the default set. I don't know where they come from.
Could I request some icons for VM Incrediblepbx & Vitalpbx? Thanx in advance for any icons created on my behalf. It can also be a generic pbx if not able to get specific branded ones.
Do you want stylized clip art or transparent photos?
