Additional USB wifi nic
tasosmpp
My router is the RT-N66U - Asus.
I want to add an additional usb wifi nic.
I understand that i cant set up the additional nic through the GUI but thats ok i will set up this nic via ssh.
I have the latest Merlin build (374.42).
The question is what wifi drivers are availabe in the firmware and if there is a nic that works out of the box.
Thanks! :D
Not sure somebody else was interested before:) You may try to compile asuswrt-merlin, then go to kernel directory, run make menuconfig to find out which wi-fi drivers are available.
PS As for me, I'm using USB-LAN dongle as 5th LAN port.
