Funnyland123
Hello, I got an Asus AX86U and installed Adguard Home on it. 2 GB Swapfile Entware and everything that was needed was also done. If I surf the net normally, everything works great. Quite a lot of DNS queries and a lot is also blocked.
To the problem: I would like eg. Watching a movie from the USB HDD in higher resolution Adguard crashes first and then the whole router. Then the router restarts and then everything works again until I try again. Even if the imac makes a time machine backup, the system crashes. If I pull the USB stick on which Adguard is (I have already tested another one), there are no problems USB works and also Time Machine. Only Adguard Logically not anymore.
Does anyone have a tip why I always crash everything?
Funny
Funny
