paulmorabi
Hi, I'm currently running AGH on a raspberry pi and thought I would give this a try instead on my AX-88U running 386.8 firmware.
Unfortunately, I've had a lot of troubles with it. Installation went through to starting and then proceeded to hang (I waited 30 minutes). Hitting contol+c reverted me to the menu where I tried a few different configuration options but it would never work. The web UI never started and the command line check always said dead. I'm now trying to uninstall but after hitting "y", it's again hanging.
I've got a tar export (gzipped) but I can't seem to upload here so if you give me an email address I'd be happy to share.
Has anyone had similar issues and able to fix it? Failing that, is there a safe way to manually uninstall?
