AdGuard
Hang on a minute. You have Forward Local Domain Queries to Upstream DNS selected to Yes. Now, please correct me if I’m wrong, but is that not the setting that sends the dns query to your ISP’s dns server? (Anyway, mine is set to No, but I seem to be seeing something similar to you. I will try my laptop instead of my iPad.)
I carried the DNS Leak Test, and whilst I didn’t see the 94.140 servers, This came up:
195.181.164.46dns.adguard-dns.com.
The “adguard” in the hostname giving reassurance. I used dnsleaktest.com.
Did your leak test perhaps send you to another adguard server?
My DNS requests go to
184.75.214.194azurebrobdingnagian.com.Amanah TechToronto, Canada
That is my problem identified now. I have to dig around and resolve it.
It should report similar to yours.
According to a DNS leak test, my DNS is a service in Toronto. It is 2 hours away and my ISP is local. Should it not say the 94.140 DNS numbers?
When I test https://d3ward.github.io/toolz/adblock.html using my laptop (Edge or Chrome even with uBlock Origin turned off), I get completely different results to those obtained when I use my iPad (except for when I run Brave on the iPad with Shields Up) - from one extreme to the other!
I don’t think you’ve mentioned which device or devices you’ve tested using, but it certainly is worth trying a different device with a different operating system, especially, if, like me, you’ve been using an iPad.
I do hope you get to the bottom of this: it’s starting to bug me.
What about your setting Forward Local Domain Queries to Upstream DNS which you have set to Yes. I think it’s supposed to be set to No, otherwise your DNS query gets sent to your ISP’s server, I believe. Perhaps try changing that setting and see what happens.
There is definitely something to check on DNS Settings ("Upstream DNS servers" as an example) and others options related to "catch" DNS query and get them redirected to AdGuard Home.
I am in Quebec and my DNS request are directed to DNS Servers I have specified in "Upstream DNS servers", not to my ISP neither to somewhere else.
Hope you will find the solution.
It should be set to No, but not for the reasons you think. It just prevents queries for local resources (internal domain, private IPs, unqualified hostnames) from being sent to the WAN DNS servers.
It won’t change his outcome, but he needs to do it anyway. :)
Start running this query:
On PC:
nslookup dnscheck.adguard-dns.com
On router:
nslookup dnscheck.adguard-dns.com 127.0.0.1
If it’s reaching AG, it will give a valid response. Otherwise, non-existent domain.
Post the results.
Many thanks for clarifying that for me. I think I now see how I might have got the wrong end of the stick for that setting. Much appreciated.
Well I
Well hey. I am 90% of the way there! I was thinking of different browsers, not different systems. Checking DNS and adblocking via my phone is correct, as is my tablet. My wife's Windows laptop is incorrect however with Windows I am just about there. I can check my kid's Mac later tonight. You do not dare even look in its direction if she is not home...
I tried entering DNS numbers in the network>adapter>ip4 settings. No luck, something still overrides that.
I am so pleased. I was going nuts. You guys were all helpful and I appreciate it.
Bj
What kind of “helpful” Antivirus tools are installed on that PC?
Well I
Bj
You wrote: “I tried entering DNS numbers in the network>adapter>ip4 settings. No luck, something still overrides that.” If you have your router’s DNS Director setting set to the Router under Global Redirection, as I believe it needs to be, then I think that may well explain why it doesn’t matter what DNS settings you put into the Windows network adapter DNS settings: that Global Redirection setting overrides other settings, or so I believe, which is really what you want to happen: it makes the router the ultimate decider of the DNS server, otherwise you could easily end up with different DNS server settings on each one of your devices and you’re left wondering why every device behaves differently.
On PC:
On router:
Post the results.
PC:
Server: RT-AX88U.AX88U
Address: 192.168.1.1
Non-authoritative answer:
Addresses: 2a10:50c0::ad1:ff
94.140.14.14
Router:
Server: 94.140.14.14
Address 1: 94.140.14.14 dns.adguard.com
Address 2: 2a10:50c0::ad1:ff dns.adguard.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
The haunted router - Global Redirection is set to Router.
Who's your ISP? Try DNS-over-TLS to AdGuard DNS and see what happens.
So you think. Look for any features like "Real Site" and disable them. They interfere with DNS.
Interesting. I turned it off and ad blocking works now! The DNS leak test shows a series of Google addresses, no Ad Guard. One big step at a time I guess.
thanks alot. Great idea.
Bj
Because I have my RT-AX86U running:
AdGuard DNS only:
With uBlock Origin:
Find what's wrong with your setup.
I used Diversion during some time and I switched to AdGuard Home ealier this year.
I have a RT-AX86U, Firmware 388.2_2.
WAN - Internet Connection, DNS settings:
In incognito mode (Edge and Chrome), so using only AdGuard Home :
And with uBlock Origin:
I think the best you can get with this test using dns level adblocking only (and no ublock origin) is 93%. If anybody can get better with only DNS level Adblocking, please feel free to share your technique or lists.
