AdGuardHome AdGuardHome Memory Usage Analysis
Have a good swap. that should be it. adguardhome should relinquish memory and use it as it needs it, but on the routers it operates in a tight amount of space. Having a good swap will atleast cushin that space.
Good swap as in, >/=2GB? I'm currently using 2GB as the recommended default for Skynet, but I can increase/decrease it if it makes a difference. Also I should have pointed out that while RAM utilization is very high (981MB used of 1024MB), I haven't experienced any stability or performance issues as yet.
should be fine.
I've noticed it gradually creeping up over time till I reboot the router.
