The error indicates that your entwares package for column is missing,or has broken, dependencies. I would recommend runningI was trying to install AdguardHome today, but when installing it asks for a timezone/location but it never gives me a list of them. Could someone provide full list so I can continue install?
opkg update
opkg install column --force-reinstall
Thank you. I will try this.The error indicates that your entwares package for column is missing,or has broken, dependencies. I would recommend running
Code:opkg update opkg install column --force-reinstall
in another SSH session. The list of timezones is pretty lengthy, as you can tell it is over 595 different numbers.
To be honest, it is all around troubling because it indicates there could be other aspects about your Entware repository which are broken. The AdGuardHome installer script relies on several Entware dependencies to fully properly install AdGuardHome on your router. I truely recommend a clean install of Entware in this case, as you don't know how deep the broken Entware rabbit hole gets. If you are not scared to find out, then proceed with the install. Adguardhome install script relies on a few other packages to properly set the username and password in the install runtime. Failure to do such results in a failed install.Thank you. I will try this.
Keep an eye on your Entware more often utilizing AMTM ep options. More and More user scripts these days are running with dependencies from entware. It is important to confirm on your end that you have kept it up-to-date before attempting to install something new. Many users have reported issues that link back to broken dependencies, or packages in need of updating. It doesn't help that entware sometimes breaks things as well during their updates.Thank you. I will try this.
Edit: This did the trick. There were many Entware depencies to update.
Your welcome to try, I don't have a RT-AX56U to test it on.My question is if RT-AX56U entry-level router can handle this:
Scripts: Diversion, Skynet, Scribe, Connmon, ntpMerlin, scMerlin, vnStat.
...plus AdGuard Home on top. Diversion obviously has to be removed.
You have to be careful with blocklists number and size, @zer0bitz. Slow CPU and 512MB RAM.
Some random reboots have occured. Diversion I had disabled since I wanted to try out AdGuard. Installation is now done, but im wondering to get Cloudflares DoT to work. I did put: "tls://1dot1dot1dot1.cloudflare-dns.com" into the Upstream DNS Servers but when going to 1.1.1.1/help it is saying that DoT is not working.My question is if RT-AX56U entry-level router can handle this:
Yep im running all scripts from SSD which has a USB adapter. Used to have a usb stick but that was complete hell to use.Your welcome to try, I don't have a RT-AX56U to test it on.
My recommendations is to have a fully functional up-to-date Entware repository preferably installed on an SSD or external HD. Skip using a generic flash drive due to future performance problems or corruption.
There have been some "optimizations" that might make it more suitable to run on these lower end routers, but it will cause a lot of CPU thrashing while lists update or load into memory.
Turn off dnssec in adguardhome, and make sure you remove any other dns servers from the upstream list that look like 1.1.1.1 8.8.8.8 9.9.9.9 as these are plaintxt (leave reverse lookup and local options alone).Some random reboots have occured. Diversion I had disabled since I wanted to try out AdGuard. Installation is now done, but im wondering to get Cloudflares DoT to work. I did put: "tls://1dot1dot1dot1.cloudflare-dns.com" into the Upstream DNS Servers but when going to 1.1.1.1/help it is saying that DoT is not working.
Is this the correct setting?Turn off dnssec in adguardhome, and make sure you remove any other dns servers from the upstream list that look like 1.1.1.1 8.8.8.8 9.9.9.9 as these are plaintxt (leave reverse lookup and local options alone).
Ok. Got them deleted and this is how my upstream dns are now. Are these correct? Anything else I can remove?and make sure you remove any other dns servers from the upstream list that look like 1.1.1.1 8.8.8.8 9.9.9.9 as these are plaintxt
Yep the test fails with dnssec option enabled. This is a known problem of those test pages. The only way to validly verify DoT or DoH is working is to look at the queries in the query log. It tells you if your plain text request are sent to an encrypted upstream.
Thank you for the advice. It is correctly working.Yes, this 1.1.1.1/help is basic. Only detects Cloudflare servers and with no DNSSEC. You can see what's used in Query Log:
Click on the ? circle for information. You'll see :853 for DoT.
My AdGuard Home installation is on another device using Unbound as resolver. This is where 127.0.0.1:5335 is coming from.
SMB shares arent working anymore
The install pre-configured all the necessary requirements for local name resolution. Dns rewrites won't be necessary.You can use phishing/malware filtering upstream DNS and make your blocklists lighter.
On my separate device I have to do DNS rewrites to make local resources work, I guess.
@SomeWhereOverTheRainBow will help you with router installation.
Yup. I added the Cloudflares malware blocking dns also. I used to have it in WAN settings.You can use phishing/malware filtering upstream DNS and make your blocklists lighter.
I truly hope! I really wish to get Adguard and Wireguard to work together.@SomeWhereOverTheRainBow will help you with router installation.
my SMB shares
Thread starter | Title | Forum | Replies | Date |
G | AdGuardHome AdguardHome install issue | Asuswrt-Merlin AddOns | 26 | |
AdGuardHome AdguardHome errors: dnsproxy timeouts? | Asuswrt-Merlin AddOns | 2 |
Welcome To SNBForums
