AdguardHome timezone
I personally would skip nextdns. You would be better mixing a variety of servers which you would be querying directly, than using nextdns which backdoors off of the same servers. You have to remember that your requests are cached. You can enable builtin adguardhome optimization cache features such as optimistic caching. You can change the ttl values for longer caching as well.
e.g. of a good mix
https://doh.cleanbrowsing.org/doh/security-filter/
tls://security-filter-dns.cleanbrowsing.org
https://security.cloudflare-dns.com/dns-query
tls://security.cloudflare-dns.com
https://dns.quad9.net/dns-query
tls://dns.quad9.net
How is NextDNS any different than other DNS resolvers? I’m not using the personalized version of NextDNS, FWIW and, for me, it’s consistently one of the fastest resolvers. That said, I’m genuinely interested in evidentiary concerns.
I was just making a suggestion, that was it. For evidentiary concerns, you would have had to seen my conversations with the developers while it was still in beta. Wish I saved those conversations. However, you are free to do as you like. Just keep in mind, you might not want to use nextdns secondary servers (unless you are actually close to them geolocation wise). If you are using nextdns, you will get best results not using parallel, but fastest IP as your dns algorithm. That way your requests will hit their primary servers more often then their secondary.
