I have an AX6100 (2x RT-AX92U) mesh system on firmware 3.0.0.4.386_41535. I have an interesting problem with how the mesh is handling DHCP with guest networks. Frequently after a reboot devices will have issues getting reconnected to my 2.4GHz guest network that I use for segmenting off IoT devices. The system logs fill up quickly with repeated
messages saying that the DHCP is unable to give an address over br1, and devices are unable to communicate as a result. On more rare occasions I've seen it also randomly hand out 192.168.100.x network addresses rather than the usual address pool (192.168.50.x) I have setup. I have tried just disabling and re-enabling that guest network, but that causes ANOTHER weird issue that makes the WAN freak out and become unavailable, saying some error about the ISP DHCP not working right.
I have figured out a workaround that involves me disabling ALL of my guest networks (I have 3 including the one mentioned above), then rebooting the mesh system (both main router and the secondary node). If I do that then re-enable the guest networks after the fact it seems like it's good to go. It's not as horribly inconvenient as I may have made it sound, but I like tinkering with the smart connect rules and such for fun so as long as I leave it alone it's stable. I'm mostly curious if anyone has had the same issue as opposed to needing an immediate solution or anything.
