AI mesh question
foug
When connecting to the router I want to use as my AI Mesh do, do I go from LAN to LAN or LAN to the nodes WAN port? Thanks.
Asus has support articles on how to setup AiMesh if you haven't already seen them.
Other AiMesh support articles can be found on the Asus Support site.
If you want to do Ethernet backhaul from AiMesh node to main router then you connect the WAN port of the AiMesh node to the LAN port of the main router.
