EastcoastJoe
Is there a way to schedule mesh optimization on a RT-AX86U?
I originally tried to bind all fixed location devices to their respective mesh nodes then ran into a limitation on the number of devices that could be bound...so I only bound critical devices. Then I tried adding all fixed location devices to the no roam list with no noticeable effect. Then I tried adjusting the threshold of the roaming assistant, but ran into intermittent connection issues with roaming devices. For some reason devices decide to move to far less then optimal mesh nodes and then stay there. The least disruptive way I found to fix this is to occasionally run mesh optimization, but it would be nice to automically do this in off hours. Binding nodes seems to work the best, so ideally if more devices could be bound that would be ideal... did this limitation ever change? May just need to try it again.
