Klueless
Hmmm ... I do admire your tenacity (I would have given up : -)
What negotiated speed do you see for the NAS to Router connection (via Ethernet)? You can check from the NAS or from the router, e.g., http://demoui.asus.com/index.asp (look to upper right, click on "status" then look to lower right of display).
Sometimes Ethernet to Ethernet connections will negotiate the wrong speed, e.g., 100 Mbps instead of 1 Gbps. Sometimes it's a bad cable. Sometimes a bad rj45 port (try a different LAN port). And, rare, just an incompatibility between devices (I once had to override a PC's auto negotiate and lock it at 1 Gbps.)
