AiMesh Node setup
A couple points....
I would work with the equipment you have. Setup a router and evaluate it and its WiFi coverage around the house before adding a node. A WiFi Analyzer app helps to see the WiFi signal levels.
I just learned that AiMesh 2.0 allows selecting a node's uplink, so this could help your situation when you have AiMesh 2.0.
When you setup a router, you should reset it before configuring it.
OE
Just installed it, but i cant find that setting. Can you tell me where its at?
Go into the the new AiMesh menu, select the applicable node, click on the managment tab:
Look for this selection, then just clcik on the box highlighted in yellow below
