AiMesh option with AC86U
sl4fko
Hi all.
So. Long story short, my AC68U is dead, it was an Aimesh node with AC86U (ETH backhaul).
The combination was working very well, so now, I am looking for a replacement. No need for an AX router, my AC86U (Merlin FW) as a main router is still in good shape + I have NO AX clients.
My only condition is, that a new router has a WHITE CASING (AC68U was also white...).
What should I get? ZenWifi (Mini?), Lyra, Blue Cave, another white AC68U... I mainly use only 5GHz AC band, 2.4 is disabled on both the main router and mesh node.
Thanks for any suggestions!
Another RT-AC86U or RT-AX86U (depending on your local prices and your budget) with a can of white paint. :)
Hi all.
Asus makes a white AX-68U - would seem to be a perfect replacement...
https://www.amazon.com/dp/B098BQ2YKT/?tag=snbforums-20
