visortgw
I have been able to separate cable Internet form cable using MoCA — my cable modem is connected at the origin of the ISP cable into the house so I have disconnected the cable run throughout the house to be exclusively MoCA (Who uses TV cable anmore?). I have successfully used both of the following to connect individual devices, but I have not attempted to connect router to AIMesh node using MoCA (I see no reason why it shouldn't work...):Yes, have coax cables, however, I have been suspect about signal interference with my cable internet, since its a 50 year-old house. Have you had good experience and does the intranetwork work fine when you have cable internet signal running in/into your home ? Any recommendations for MoCa adapters for only up to Gigabit Moca (won't need 2.5 Gbps, 1 Gbps would work fine for me). TIA.
There are other brands available, but I would stay away from TRENDnet since their switches don't support VLAN tags, which are necessary for Asus' VLAN implementation.I am not sure about 1 Gbps MoCA adapters.
