octopus
Part of the Furniture
Just to aske if somone run Aimesh with 5 Ghz wifi backhaul.
I have every 24 hour disconnects. I don't know if it's by design or some connecting missing configuration.
RT-AX86U as master Aimesh and RT-AX58U as node.
May 30 06:43:27 kernel: wl0: random key value: 72C495774BABF447596401302002FC12948F8AE76B2F0D01B8360FED6A730CD5
May 30 06:43:27 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 3C:7C:3F:44:FD:21, status: 0, reason: Unspecified reason (1) <<<=== 2Ghz
May 30 06:43:27 kernel: wl0: set timeout 5 secs to wait dev reg finish
May 30 06:43:27 kernel: CONSOLE: 914602.660 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:47:9a:32: Failed. status 37 wsize 64 policy 1 <<== Chromecast gen2
May 30 06:43:27 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
May 30 06:43:27 kernel: br0: port 10(wds0.0.1) entered disabled state
May 30 06:43:27 kernel: device wds0.0.1 left promiscuous mode
May 30 06:43:27 wlceventd: wlceventd_proc_event(534): eth6: Assoc 3C:7C:3F:44:FD:21, status: Successful (0) <<== 2Ghz
May 30 06:43:27 hostapd: eth6: STA 3c:7c:3f:44:fd:21 IEEE 802.11: associated
May 30 06:43:27 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 30 06:43:27 hostapd: eth6: STA 3c:7c:3f:44:fd:21 RADIUS: starting accounting session 9BBC8C90D91DBFCD
May 30 06:43:27 hostapd: eth6: STA 3c:7c:3f:44:fd:21 WPA: pairwise key handshake completed (RSN)
May 30 06:43:27 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 1 wfd_idx 0
May 30 06:43:27 kernel: device wds0.0.1 entered promiscuous mode
May 30 06:43:27 kernel: br0: port 10(wds0.0.1) entered listening state
May 30 06:43:29 kernel: br0: port 10(wds0.0.1) entered learning state
May 30 06:43:31 kernel: br0: topology change detected, propagating
May 30 06:43:31 kernel: br0: port 10(wds0.0.1) entered forwarding state
May 30 06:43:37 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 3C:7C:3F:44:FD:24, status: 0, reason: Station requesting (re)association is not authenticated with responding station (9)
May 30 06:43:37 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 3C:7C:3F:44:FD:24, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
May 30 06:43:37 hostapd: eth7: STA 3c:7c:3f:44:fd:24 IEEE 802.11: disassociated <<== 5Ghz
May 30 06:43:37 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 1
May 30 06:43:37 kernel: br0: port 11(wds1.0.1) entered disabled state
May 30 06:43:37 kernel: device wds1.0.1 left promiscuous mode
May 30 06:43:37 kernel: CONSOLE: 914612.807 wl1: random key value: 674023E4891C42DE3B390253039B1D0672041792C1F10A040F7D3F1D35C22D1B
May 30 06:43:37 kernel: CONSOLE: 914612.808 wl1: STA 3c:7c:3f:44:fd:24 has disassociated tx_type 2 <<== 5Ghz
May 30 06:43:37 kernel: CONSOLE: 914612.808 MQ: wlc_tx_fifo_sync_complete: TXPENDTOT = 1
May 30 06:43:37 kernel: CONSOLE: 914612.808 MQ: wlc_tx_fifo_sync_complete: fifo 3: collected 1 pkts
May 30 06:43:37 kernel: CONSOLE: 914612.808 dngl_finddev: slave 1 not found
May 30 06:43:37 kernel: CONSOLE: 914612.809 dngl_finddev: slave 1 not found
May 30 06:43:37 kernel: CONSOLE: 914612.811 iov:SCB_DEAUTH
May 30 06:43:38 wlceventd: wlceventd_proc_event(534): eth7: Assoc 3C:7C:3F:44:FD:24, status: Successful (0) <<== 5Ghz
May 30 06:43:38 hostapd: eth7: STA 3c:7c:3f:44:fd:24 IEEE 802.11: associated <<== 5Ghz
May 30 06:43:38 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 30 06:43:38 kernel: CONSOLE: 914613.976 wlc_ap_authresp: status 0
May 30 06:43:38 kernel: CONSOLE: 914613.993 wlc_ap_authresp: status 0
May 30 06:43:38 kernel: CONSOLE: 914613.996 wl1: turn sta MFP setting on with sha256
May 30 06:43:38 kernel: CONSOLE: 914613.996 wlc_ap_process_assocreq_done status 0
May 30 06:43:38 kernel: CONSOLE: 914613.997 wl1: STA 3c:7c:3f:44:fd:24 has associated tx_type 2 <<== 5Ghz
May 30 06:43:38 kernel: CONSOLE: 914614.000 iov:SCB_DEAUTH
May 30 06:43:38 kernel: CONSOLE: 914614.001 tx:prep:802.1x
May 30 06:43:38 kernel: CONSOLE: 914614.072 tx:prep:802.1x
May 30 06:43:39 hostapd: eth7: STA 3c:7c:3f:44:fd:24 RADIUS: starting accounting session 5295E113D68A9493
May 30 06:43:39 hostapd: eth7: STA 3c:7c:3f:44:fd:24 WPA: pairwise key handshake completed (RSN)
May 30 06:43:39 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 1 wfd_idx 1
May 30 06:43:39 kernel: Register interface [wds1.0.1] MAC: 24:4b:fe:d4:ea:0c <<== 5Ghz master
May 30 06:43:39 kernel: device wds1.0.1 entered promiscuous mode
May 30 06:43:39 kernel: br0: port 11(wds1.0.1) entered listening state
May 30 06:43:39 kernel: CONSOLE: 914614.997 tx:prep:802.1x
May 30 06:43:39 kernel: CONSOLE: 914615.004 tx:prep:802.1x
May 30 06:43:39 kernel: CONSOLE: 914615.007 iov:SCB_AUTH
May 30 06:43:39 kernel: CONSOLE: 914615.368 wl1.0: wlc_send_bar: for 3c:7c:3f:44:fd:24 seq 0x1 tid 0 <<== 5Ghz
May 30 06:43:40 kernel: CONSOLE: 914615.598 wl1: 3c:7c:3f:44:fd:24: addba timed out 0
May 30 06:43:40 kernel: CONSOLE: 914615.599 wl1.0: wlc_send_bar: for 3c:7c:3f:44:fd:24 seq 0x3 tid 5 <<== 5Ghz
May 30 06:43:41 kernel: br0: port 11(wds1.0.1) entered learning state
May 30 06:43:43 kernel: br0: topology change detected, propagating
May 30 06:43:43 kernel: br0: port 11(wds1.0.1) entered forwarding state
May 30 06:43:44 kernel: CONSOLE: 914620.000 wl1: link up (wl1)
May 30 06:43:45 wlceventd: wlceventd_proc_event(505): wl0.2: Auth 04:8C:9A:45:8F:72, status: Successful (0) <<== my mobile
May 30 06:43:45 hostapd: wl0.2: STA 04:8c:9a:45:8f:72 IEEE 802.11: associated
May 30 06:43:45 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 30 06:43:45 wlceventd: wlceventd_proc_event(534): wl0.2: Assoc 04:8C:9A:45:8F:72, status: Successful (0) <<== my mobile
May 30 06:43:45 hostapd: wl0.2: STA 04:8c:9a:45:8f:72 RADIUS: starting accounting session 78CB64660FA9CD84
May 30 06:43:45 hostapd: wl0.2: STA 04:8c:9a:45:8f:72 WPA: pairwise key handshake completed (RSN)
May 30 06:43:55 kernel: CONSOLE: 914630.635 wl1.0: wlc_send_bar: for 3c:7c:3f:44:fd:24 seq 0x1 tid 6 <<== 5Ghz
