RT-AC86U Main Router
2x RT-AC5300 Nodes
1x RT-AC68U Node
Have been using AiMesh since its official release and I continue to use it. All of my above routers are running the latest AiMesh firmware on each router. In General, I am not using QoS, Smart Connect, and or VPN, AiProtection and RA is also enabled. In my environment, I have also disabled the 5GHZ band, because of stability, nodes going offline. It has helped in my environment.
Biggest issue,
stability of nodes.
My bucket list/suggestions/observations, for the future development work of AiMesh deployment:
- Node support for Guest Account/s should be available.
- Client Mac address Filtering by Node should be available.
- Interface connection type, being visible on the Node client listing by client
- Mac Address of clients, being visible on the Node client listing
- Ability to change/modify client names via the Node client listing
- Ability to change/modify the transmit signal strength level on Nodes
- A Reboot Schedule MUST be available on Nodes.
- Continued improvement of Stability issues - Offline Nodes.
- Have a led light indicator (red) at the node (router) level, so that when according to the Web UI, a node has gone offline.
- Continued improvements of main router client listing (ALL), i.e. showing correct interface type connection, still not correct after latest firmware update for the AC86U, (even after completing a factory reset/initialize and then completing a manual reconfig of the main router AC86U.
- Improved compatibility between tri and dual band routers, e.g. not being able to disable the second 5GHZ band on a tri band router (AC5300) as a node, when using a dual band main router (AC86U), i.e. when disabling the 5GHZ on the main router AC86U, one 5GHZ band is still running on my both AC5300 nodes.
- Firmware updates (generic AiMesh Fixes) for ALL compatible AiMesh routers being available/deployed at the same time. I understand this could be more difficult, as different problems may only exist on different router types.
- More AiMesh beta firmware releases (where possible), from ASUS, for user testing to this forum. It has gone a bit quiet of late.
- Continued Improvement of Mouse hover help over router settings. e.g. a ? is displayed over the Multi-User MIMO settings field, but no description is displayed (AC86U).
Comprehensive I know. I hope it's not too long winded in reading for everyone.
Over to ASUS techs, for anything that might be meaningful, in my above comments, to ASUS going forward with AiMesh, both in terms, of development/enhancements, as a firmware and marketing tool. I am hoping that someone from ASUS (any acknowledgement) reads my comments and takes them on board for discussions within ASUS..
Please free anyone to jump in and add own your comments and suggestions about my post.
And more importantly, any suggestions or problems with AiMesh,
we should ALL (AiMesh Users) continue to send an email with the appropriate backup, to ASUS for support. Complaining about a problem wont help,
unless you have already conveyed your problem/suggestion/s to ASUS support about AiMesh.
