noobgonewrong
Hi
i got a AX88U as main node and 2x AX58U as nodes.
all have same firmware ( AWRT 386.5_2)
the first node is connected with cable. but the second one is in my tenants appartment and out of reach for a while. so i cant reboot or reset this.
the second one wont connect after a reboot of the system.
when i use netspot, i can see that it jumps from channel 1-3-8 on 2,4 ghz and stable on channel 40 on 5 ghz.
on the main node (AX88U) 2,4 ghz is set to ch 9 and 5 ghz is set to ch 40.
if i change my primary channel to example ch 3 as the rouge aimesh node mostly is at, then the rouge node changes its ch to 9..
it broadcast SSID ( same as my main node) and when i can connect to it with laptop and phone. but "router.asus.com" isnt working, just say connected and no internet available.
is there someway i can get it to reconnect without accsess to the node?
