I tried to enable IPTraffic under Tools -> Other Settings but when I applied the setting, my router hung. The only way to recover was to do a hard reset and then reconfigure the router. The only thing that I can think that might have caused this is that I neglected to check "Create or reset IPTraffic data files". Would that hang the router?
As an aside, the reason that I was trying to enable IPTraffic was that on the Traffic Analyzer -> Statistic page, it states "You should turn on the Traffic Statistic to record the traffic information". Unfortunately, it is not clear to me exactly where one turns on Traffic Statistic. Are IPTraffic and Traffic Statistic synonymous or is there another setting?
All information greatly appreciated.
